Today I sanded the intersection fairing to main wheel fairing interface and then microballooned the interface to get a smooth flowing transition between the two. Next I mounted them on the gear leg, drilled all the various holes to final size followed by riveting on of the nut plates. I also worked on the nose wheel fairing; bonding on a filler strip on the top leading edge of the aft fairing section.
Fairing interface microballooned and sanded
Wheel fairing anchor nuts riveted in
Nose wheel fairing top leading edge filler strip added
